Old Feb 12, 2016 | 10:33 AM
MrMoPar's Avatar
MrMoPar
Default FS - 2005 SRT6 rolling chassis
I have a black 55K mile 2005 SRT6 rolling chassis I need to get out of my garage.
It was hit in the passenger front outside of the frame rail. This is a parts vehicle only, cannot be rebuilt, have paper work.
No front sheet metal, front fascia, windshield trim, etc., no engine, no electronics/electrical unless mentioned below.
What it does have; (major items)
Body wiring harness, fuse box, full suspension, full exhaust, transmission, driveshaft, rear differential, rear half shafts, fuel system, fuel tank, ABS pump and control module, brake booster and master cylinder, brake lines, rotors (no calipers), hubs, control arms, steering gear box and steering linkage, steering column, sitting on four 19” rims (fair condition).
Bodyparts;
Driver side door undamaged but has scratch in paint, rear quarters good, rear fascia good, rear hatch good (no wing or SRT6 logo, has CROSSFIRE letters), passenger door sheet metal is damaged.
Both doors have air bags, window glass, regulator and motor. Driver door no door panel, passenger door has door panel, both have lower speaker, door latches, door handles. Roof section is good. Rear quarter windows good, rear hatch good. Side mirrors included on doors.
UPDATE: does include driver side front fender with silver trim. No exterior damage, the inside vertical mounting flange that bolts to the inner fender well is sprung next to the windshield. If it is actually bent, easily straightened by a body shop on their sheet metal brake. Also included is the driver side plastic lower rocker panel cover also in good shape.
Both seats good, has major Black dash panels, (no console or silver trim, no steering wheel or lock assembly), as mentioned, has passenger side door panel, (no headliner or visors). Does have the inside rear quarter window trim and the trim piece that goes across the bulkhead behind the seats, rear storage area trim panels, carpet.
Lots of other small parts too numerous to list.
This can be rolled up onto a trailer, or could be towed on a tow dolly.
$1200 firm, you pick up in 43452 area. The tranny, rear end, half shafts alone are worth the price. I am listing this at this price to get it moved, my loss is yourgain.
PM me or text me (fastest) 419*573*2122
