Re: Finally, TPMS bypass on my '08
ALso, it is worth mentioning, that any issue that 2-5 psi might cause such as the light coming on when cooler, you should always check with different gauges. I knew someone that was a total nut about air pressure because of something he read. And he kept a gauge in every car, and checked every week. It ended up that the 3 gauges he had would read something like 28,30, and 35 on the same tire. Never trust 1 gauge, or 1 tire pump, if you care about how exact the reading is.
