maxcichon
I've done a few of these on our cars, and more than a few on old US V8's.
I've yet to see an oil leak from the OEM Mercedes valve cover gaskets. The BUNA/aluminum seal seems to work perfectly, unlike the old sheet-steel VC's of my youth.
I apply a very light coat of silicone vacuum grease (viscosity-stable to 212F) to the gaskets, just because it's the way I do it.
The RTV you add, IMHO, does nothing. The Germans got this one right.
The RTV they use, or the application of it, is a real issue. More leak, with time, than don't.
But I've had great luck (?) using my method of true-cleaning and proper application of "Black" Permatex.
And, that's MY 2 cents.
The value of advice, in general, is inversely proportional to it's cost.
Chew on THAT one, folks!
I'll go along with this method, why add something that is not needed. If you have to go in there again for some reason you have to waste time getting the stuff off.
Fortunately I have had no leaks, touch wood, but I know how I would fix them, I'd use maxichons methods for covers and vents.
