Old Feb 21, 2016 | 04:20 AM
  #4315 (permalink)
syfi's Avatar
syfi
Originally Posted by pioneer4x4
K&N Anyway, just to confirm, there are 4 for the filter itself, correct? I didn't miss anything, did I. And funny you mentioned the dipstick, because I checked that first, and pulled it out to let air in do drain better, and the O-Ring is pretty loose on it, I was going to ask about replacements. Also, it got close to 70 degrees today, not bad when it was 9 below last week.
The filter fits many different models, some of which require the additional o-ring. Ours always have a left over one. Uses only 4 rings. Also, invest in an oil evacuator, such as the Mityvac 7201. Easiest, cleanest and most effective way to change oil, and it's the recommended way by Mercedes (it's how they do it at all dealerships). The 3.2 liter motors were designed to use evacuators exclusively!
Mityvac 7201 Fluid Dispense/ Evac - Lubrication / Hose Reels
