For a little better cooling: 1.) Give the system a good flush and then use a minimum antifreeze ratio for your coolant and use a water wetter(example 15% antifreeze & 85% distilled water). 2.) Remove the rear hood gasket at the cowl, to allow some of the heat to escape. 3.) Move to a cooler climate.
