Re: supercharger pulley gap?
"The gap between the clutch plate and the pulley is determined by the stops that the spring pulls the clutch plate back to"...That's not the only determining factor as we found recently. The shim behind the SC pulley bearing and the amount of shims on the SC shaft have a lot to do with obtaining proper clearance gap
