Old Feb 25, 2016 | 10:56 AM
ala_xfire
Default Re: Relocation of the horns with the Needswings DCAI
Horns ? I don't see no horns. Maybe you isn't a steer ?
Seriously, you can relocate them to the main frame above, there are already lots of holes in it that you can use, only problem is you will have to extend the wires.
Use soldered, heat shrink connections to do that, just cut the terminal ends off and put the extension between them and the normal wiring.
Welcome to the forum !
