chuK_138
Should've gone with 5mm spacers....
I did not think that 5mm would be big enough. Reading through the forums, it seems as if 10 would work without mexi-poke. It pushes the wheel out to exactly flush.
Plus, the 5mm's do not look to be hub centric:
PRO-SPACER Kit | Eibach Springs
So far, this is turning out to be an exercise of "trial and error" so, if the 10mm look too big and I have more than enough clearance, then I will return those and get the 5mm's. At least Amazon has a good return policy.
