csteve0355
Here is a tip as it only took me 5 min. to change the 2 exhaust donuts.
I cut 1 off with a razor blade then jacked up the muffler - then put the donut on the muffler hook then took a thin flat blade screw driver and pried it over the top body hanger, and while holding the screwdriver up pulled the donut over the body hanger. Then repeated for the other side. As I said it took no more than 5 min. total to remove and replace both sides.
Hope this tip helps others here on the Forum.
Thanks for the tip ! I'll remember that.
