Old Feb 29, 2016 | 04:03 PM
Mackel's Avatar
Mackel
Default Re: 2005 ignition key issue
Originally Posted by beachguy
onehundred80,
I'm reviewing the pdf for tackling tomorrow. Is it absolutely necessary to take out the tumbler as you describe in #10? KDW4Him sent me pics and the tumbler and key are still in the assembly when removing the pin and spring. Can you clarify? Thanks!
I just did this 10 days ago and I was impressed to see the pictures in this thread with the
tumbler and key still in the ignition. I removed the tumbler per the pdf but getting the tumbler
re-inserted was touch and go. I can see where some folks would have a problem getting it back in.
The key in KDW4Him's picture appears to be in position 0.
I assumed that moving the key to the ON position (position 1) would unlock the steering column in
order to get the ignition housing out. Maybe not.
Eliminating that step would make it some easier. Looking back over the pdf I'm not sure what was accomplished by removing the tumbler.
Surely onehundred80 will impart some wisdom.
