Caliper upgrade. The Front calipers to be installed in the rear
All,
I'm trying to locate a thread on using the front calipers in the rear of the car (since the stop tech are in the fronts). I will get new larger slotted rotors, I will try and re-use the barely used Rotex Gold pads from before.
BTW any rust and crud solutions I can deep the caliper in? If not, I can machine and sand them prior to paint them new. Need to ensure all products design for high temperature.
*Double post since the other had an auto correct stuck to it.
