ptrustfull
Lights turn on. The lock/unlock button on the dash does not work. The tow switch light stays on all the time and the spoiler light keeps blinking when ignition is on. Spoiler does not move. With ignition on all usual dash lights turn on. I checked the violet wire going to the starter and both are good. Noticed that when i put a test light at the ground sensor wire (pink/red) the starter motor turned. I also mentioned that i am not able to read OBD codes "no communication with ECU". Also measured the ground sensor wire (brown/yellow) to the ECU and i am getting 0.00 volts with ignition on. Before i take the conclusion that the ECU is fried i will need to find all ignition and battery wires going into the ecu and see if they get juice. Allready measured all fuses twice and they look good. Maybe one not important thing. As sson as i switch the car on the fan starts running at top speed. I purchased the manual so i can trace all wires and stuff. Help is greatly appreciated
