Old Mar 7, 2016 | 10:38 AM
Kaktis993's Avatar
Kaktis993
Default Re: Another BAS/ESP Conundrum
Originally Posted by Bill F
Have you tried this:
Synchronizing ESP
If the power supply was interrupted (battery disconnected
or discharged), the BAS/ESP malfunction indicator
light may be illuminated with the engine running. To
re-synchronize the ESP, and cancel the malfunction indicator
light, the steering angle sensor will need to be
recalibrated.
1. Turn the ignition switch to the ON/RUN position.
2. Rotate the steering wheel to the center position.
3. Rotate the steering wheel completely to the left, and
then rotate the steering wheel completely to the right.
4. Bring the steering wheel back to the center position.
5. The BAS/ESP malfunction indicator light will go out.
If the BAS/ESP malfunction indicator light is still illuminated,
the vehicle should be serviced at an authorized
dealer.
Hi Bill, I gave that a try with the engine off and key in run, and then also with the engine running. No luck either way. Thanks though, I appreciate the suggestion.
