Oil Change Weird Happening
This past weekend, I performed an oil change on the 2007 Coupe. Everything went extremely well. I started up the car to check for leaks and all looked good. Then all of a sudden, the car shut off! Turning the key yielded nothing! After the car sat for a few hours, started right up again. Then after 5 minutes or so, shut of again. Left the car alone for the rest of the day.
Next morning. started the car up and all is back to normal. Wonder whether I had an oil level or flow issue that the sensor detected. If so, I think it would shut off the car to prevent damage. Any thoughts? Maybe CPS? Haven't been able to pull any codes. Probably will try again later today.
