velociabstract
Check the fuel pressure. Your fuel filter may be clogged or fuel pump on it's last legs. If your fuel pressure is good, I'd guess it's the RCM.
Les
I think Valk had similar problems and he changed the filter. I should check back on that but maybe he will chime in.
I think the pressure regulator quits working. Maybe it's the check valve, that's on the pump I think.
