Old Mar 8, 2016 | 06:51 PM
ala_xfire
Default Re: Top wont go down
To manually put the top down.
1. lower both windows.
2. release the top "D" handle and raise the front about 6"
3. open the trunk, use a 6 mm allen wrench to release the rear bow latch. Make sure the divider is in the "top lowered" position, close the trunk.
4. raise the rear bow, release the tonneau cover with a thin 10mm open end wrench, or the special tool.
5. holding the tonneau open ( helps to have a friend ), carefully lower the top.
6. close the tonneau cover, secure it with the 10mm or special tool.
Mark points out the location of the above 2 latches in his video.
( AND - his video DOES cover lowering the top )
https://www.crossfireforum.org/forum...operation.html
