Old Mar 8, 2016 | 07:58 PM
dedwards0323
Default Re: Oil Change Weird Happening
Originally Posted by pioneer4x4
Yeah, sounds electrical, not oil related. Double check battery posts, RCM maybe. When turning the key, put the headlights on, if they are dim and get worse when you try to start, I'd look at battery and cabling. IF they are full bright, and don't change or only get slightly dimmer when trying to start, I'd look at starter motor/RCM circuits. RCM would fit for engine stopping while running as well.
I doubt that battery is the issue. Now I did still have the OEM Varta in my 2007 Coupe. Nine years of trouble-free service. But the last few weeks, I got the mysterious "spoiler gremlin" whenever I started the car. Even after a full charge, the spoiler opened when I started the car. So I replaced the battery with a Duracell from Batteries Plus. (Note: FWIW - The Duracell H6 battery is slightly taller than the Varta. Just enough that the leading edge of the clamp contacts the edge of the battery when you tighten everything down.) Got a 10% off credit since I bought it online & picked it up at the store. Cleaned the cable connections & posts before I re-connected everything. So I think I'm good-to-go there.
I haven't experienced any of the issues surrounding "mystery no starts" or engine shutoff like a lot of owners have experienced. May be just getting around to my turn.
Later,
