Gas full door spring broke
Mar 11, 2016 | 12:14 PM
permalink
croneca
Nov 2013
Granite Falls, WA
Re: Gas full door spring broke
It was an easy disassembly. Removed the filler door pneumatic locking actuator, locking pin and rubber over flow hose. Removed cap from tank, 4 clips held the assembly to the rear panel and it came right out.
Here are the 4 clips locations to get the assembly out of the fender, two on top and two on the bottom:
Here is a pic of the hinge, it has a key way formed in the center. The plastic key on the hinge pin broke.
Spring connected to the hinge pin. I ended up super glue the pin and fill door back together.
I am back up and running with a closed fill door again. Thanks for the help, have a great weekend
croneca
View Public Profile
Find all posts by croneca
