Thread: Not starting
Old Mar 13, 2016 | 10:04 AM
onehundred80
Default Re: Not starting
Originally Posted by AWM08
I bought a 2006 Crossfire in November. About 10 days later it would not start. I did a little research and found that the trouble is often with the ECM. I had the points soldered and it then ran fine. Now it it is not starting again. Could this be the ECM again already or is it more likely something else? I drove to work without incident. When I left to go to a meeting, it started, went a few feet and then stalled and I haven't been able to restart. I had the battery checked and it was fine. Any suggestion?
We should not assume that it ever was the RCM. There are other parts that work on and off before finally dying.
Does the starter make the engine rotate or not, can you hear a fuel pump when you turn the ignition key to the first position.
Give as much info as you can and you will get better help.
