Old Mar 14, 2016 | 10:09 AM
onehundred80
Default Re: NO to little BRAKES
Originally Posted by Hurricane
I own a STR6 convertible with only 7000 miles. The vehicle has been sitting awhile uncover in storage. I decided to start it up the other day and take it for a drive when I noticed the brake pedal went straight to the floor. I could pump the pedal rapid and get a little braking but after the pedal would go straight to the floor. I did notice though with the engine not running I would have brake pressure near the top. Only with the engine running did I lose all brake pressure. I have NO LEAKS whatsoever. Any advice is greatly appreciate.
I would say the master cylinder has a leak internally. Have someone push on the peddle while you look inside the open brake fluid reservoir you might see the oil getting disturbed near the bottom of the tank as it comes back through the seals.
