Old Mar 17, 2016 | 12:56 PM
onehundred80
Default Re: Kenwood KMR-D362BT install ?
Originally Posted by Abaton6
I got this head unit on the advice of a few folks here. I have two questions regarding installation: 1. The antenna connection is not the same. Is there an adapter available for this? 2. The stock plug does not fit the Kenwood. Is there an adapter for this, or did you cut and splice all the wires? I'm looking forward to using this. The stock head unit skips too easily. Thanx in advance for any assistance.
The sticky on this install will show you the parts you need, also the wire that has to be moved.
The nav radio comes with the correct antenna fitting.
