Re: Need Help! P0505 idle control!
Were you having symptoms before the work you did? I ask because I got that code when my intake manifold bolts loosen up and were leaking. Check them but be careful not to strip the bolt heads. 20nm or 15 ft lbs. Does it run good under heavy throttle? Bad at cruise and light throttle?
Les
