Old Mar 22, 2016 | 11:37 PM
4drturbo's Avatar
4drturbo
Default Re: Throttle body spacer
Originally Posted by velociabstract
I hate to tell you this but your custom intake is all metal and has no give. The only rubber is the throttle body gasket and it's getting torn apart when the engine torques over or otherwise moves around. All the other intakes have silicone hose to the throttle body for that reason. It can twist and allow some movement. You'll have to figure out where to modify what you have for some give and flex. IMO.
Les
what this guy said. Plus t-bolts are not needed. Overkill
