Old Mar 23, 2016 | 01:02 PM
dpeel82's Avatar
dpeel82
Default Re: Finally got the SRT6 back from the tune shop - Adventures ensue
Wow, thanks guys, you're awesome. I can't tell you what a relief it is to have this type of support system to help me through my teething issues.
I do have a scanner and I did scan the car yesterday:
P0108
P0410 - Pending
My tune guy suggested that the check engine light would come on periodically since with the DCAI installed it was getting much more air flow than the map sensor was used to, but they don't have any experience with SRT6s, mostly GTRs, Zs, STIs, EVOs, and BRZs.
I don't think that the coolant leak is coming from the intercooler as I had them check out the y-pipe for sludge and residue when they installed the DCAI, and they said it was clean. They think it might be a small hole in the radiator, but didn't have a big enough hose opening to pressurize it. However they will be ordering one to take care of problems like this in the future FWIW.
As far as the MAFS I wish I had known, but I expect I can return it for a refund. And now that I've owned it for a while I think that the heat soaking issue is what I was experiencing, especially with the 185mm pulley, when I pushed it hard for too long. A Waldig intercooler is probably going to be installed down the line.
Dan
