Check out XenonDepot.com
With so many makes, models and trim levels of vehicles it is important that you check and make sure what type of bulb your particular vehicle needs. You can find the type of bulbs your specific vehicle uses in several locations. One place is the head light lens, the bulb type will be molded into it. Another place is on the bulb itself, the bulb type and wattage will be printed or molded into the base. The vehicle owner's manual may also tell you what type of bulb you need for your head lights and/or fog lights. Our Bulb application chart is not always correct so please be sure to double check with your dealer or owner's manual.
An H4 bulb is also referred to as a 9003 or an HB2.A 9004 bulb is also referenced to as an HB1. A 9005 bulb is also referred to as a HB3. A 9006 bulb is also referred to as a HB4. A 9007 bulb is also referred to as a HB5. H.I.D. bulbs are referred to as 9500, D2R, D2S. H1, H2, H3, & H7 bulbs are usually referenced as such.
