Old Apr 6, 2016 | 11:28 PM
kingdavid54's Avatar
kingdavid54
Default Re: Car dies after about 40 miles..... no codes.
Originally Posted by mobilefitt
Recently I changed all my wires and coils with some cheap replacement parts. Car was running fine until it decides that it is going to power down slowly at 75mph. The throttle was unresponsive, but I could cut the car off while rolling and cut it back on again so electrical seems to be ok. I am getting misfire codes only, sometime 1-2-3 some time 3-4-6 and so there is no rhyme or reason for the misfires and so I am wondering if it is fueling.
I changed out my fuel pump, back to my original pump because the new cheap one was quite loud and when the car dies, I don't think I can hear the fuel pump click on when i try to start the car after it's been running.
So, car dies after about 40 miles. If I let it sit for a couple of hours, it will go about 40 more and then cut off.
Car will actively misfire in 3 rd gear at 3500 rpms or higher resulting in check engine light and sometime flashing check engine light. If I keep the car under 3500 rpms, there is no misfire, no check engine lights, no codes, but the car still will die after about 40 miles of driving.
What could it be?
Forget the wires and coils that's not your problem your problem is fuel-related it is obvious at higher RPMs the engine is leaning out , in other words starving for fuel and causing the misfires because it is running out of fuel, determine what's causing it and you will fix your problem, I would concentrate on looking at fuel pump fuel filter or fuel lines.
( car slowly Powers down at 75 miles per hour) classic symptom of running out of fuel.
