ala_xfire
Still probably a bad relay, or corroded contacts on a relay in the RCM.
Take the cover off with it still connected, make a note of what relays do what when you have someone turn the key : ( the engine control relay in particular, I think the fuel pump relay is OK since you can hear that running )
RCM relays
The TC, air pump and horn relay don't matter at this point.
BTW: check all the RCM fuses with a meter.
I was unable to find any blown fuses but I'll check with a meter. I also get my wife to turn the key when she wakes up. What should I be looking for? Ty
