Re: Wiper Arm
meh03
Well I left in under tension from the gear puller all week with oil to soak down the spines. No luck. Tried tapping on the end of the puller too. Just to make sure, there is nothing that holds the whiper arm in place other than the 13mm nut correct?
If I can't get it off soon I'm probably just going to unplug the dang siren.
Oil?
What kind of oil would that be?
This mixture is supposed to be the cats meow when used as a penetrating fluid.
Acetone and brake fluid or transmission fluid mixed 50/50.
Shake up thoroughly all the time.
Keep the brake fluid off paint as it may mark it up badly.
