Old Apr 16, 2016 | 11:37 AM
onehundred80
Default Re: Locking/unlocking issues
Originally Posted by JereRB
2004 Chrysler Crossfire. I know the locks are an issue with this car. I have searched, did some reading, but didn't find anything that quite matched my situation. So here we go:
Locks: will unlock, won't lock.
Key fob: lock button will not lock driver's or passenger's lock, or fuel door or trunk. If doors are locked manually, unlock button will unlock them both with 1 press. When unlock button is pressed, you can hear the vacuum pump in the back activate and unlock. When lock button is pressed, cannot hear it activate. You can see the lights flash from the outside when either button is pressed. But only unlocking/locking happens with unlock button. Can't tell if unlock will unlock the fuel door or trunk due to not manually locking them or knowing how.
Central console lock/unlock button: nonfunctional. Lock does not lock anything. Unlock unlocks nothing.
I replaced the vacuum pump in the trunk today. Previously, nothing would lock or unlock by either the key fob or central console button. Replacing the pump at least got me to unlocking. Replaced the number 9 fuse, no change. Checked the trunk area where the pump was located. It's bone dry.
So...any idea where to go from here?
The center console only locks on the roadster, not the coupes.
I assume manual locking is pushing down the passenger side button and using the key to lock the drivers door, does this lock the trunk hatch door? I assume the answer to this question is no.
Using the key to lock or unlock the car will normally activate all the locks without using any radio signals, so if the key does not activate all locks the problem will lay in the wiring or another module. I have to think about it some more.
