So after a new alternator, brakes and flushing (break code), battery, buying a code reader, the problem was a bad ground cable from the negative terminal. Has a bit of a rough idle but she starts everytime
. I'll check tomorrow to make sure I tightened the tension on the s belt enough. Can you over tighten it?
