After a year of ownership and lots of thinking, I want to go to town on really modifying the engine and drivetrain (in conjunction with suspension + brakes; these I have figured out already).
A couple of things before I start....
- Please dont tell me my car will never be as fast as an SRT6, as I know it never will be
- Please dont tell me my car will be nearly unsellable once I'm done, I have no doubt that's the case
The reason I want to go down this route is to learn. I've been tinkering with cars ever since getting my provisional, but have always been fearful of working on anything beyond valve cover gaskets/plugs/wires and standard service items (oil changes/filters/coolant/belts etc).
Hope that doesnt come across as rude, just wanted to get that out of the way before cracking on
So, what I'm really looking to do identify the performance modifications I can make to my engine and drivetrain without going forced induction. The reason for this is the m112 is notoriously hard to force induct (heat issues/space issues/requirements for fabrication of mounts etc) and to be honest, I would like to go down this route - after taking care of other aspects first. I dont have the skills or knowledge to competently do a forced induction build without messing something up big time.
My car currently has:
- Cat back exhaust (rear cats removed, primaries in place)
- 3'' dcai running into the C320 airbox, K&N air filters to a 3'' MAF and 74mm TB
- E55 engine mounts (to reduce engine flexing as I read the M112 uses the mounts to reduce rotational inertia introduced by the balance shaft)
And a few minor things that arn't worth mentioning (sprint booster for example).
These are all pretty cheap bolt-ons. A few things spring to mind on how to get further gains:
1) port/polish the head
2) Fit 3-2-1 exhaust headers
3) High-flow cats (still trying to asses if these are even worth while to be honest, I'm curious if they will help more so because the cats are 10 years old vs being actually 'high flow)
4) Larger injectors (need to investigate cycle performance of the current ones, reading that at this point they are at max)
5) Further cool air intake (no idea how, need to figure out)
6) E55 fuel pump
7) ECU tune!
8) Karmaan camshafts
The thing is, this is all simple bolt on stuff. Does anyone know of any other mods that can be applied to the M112? Apparently the internal are forged already, and researching online brings up jack all!
The car may even end up slower than an NA but I'll learn a lot.
