Mrmiata
If the CPS is out.. it will crank till the battery is dead.
Well I'm not saying you're wrong so let me give you some examples of what mine did, never fail to start when it was cold, on occasion it would stall when you came to a light or stop sign, sometimes it would start right back up but most often it would do nothing, no starter engagement no click no nothing, let it sit for 15-20 minutes and then most of the time it would restart, sometimes after driving for just a few minutes I would shut it off go in and run an errand and it would just turn over but engine would not start, would have to reset by removing negative battery terminal, in all of those times it had only thrown a code once , and it was the crank position sensor code. So I honestly don't know what to tell you these cars are very very quirky. When I pulled it out it was the original CPS still had Mercedes Benz on the side of it 11 years old and 110,000 miles.
