Old Apr 19, 2016 | 05:43 PM
kingdavid54's Avatar
kingdavid54
Default Re: Car Won't Start :(
Originally Posted by KrisFire
I just went out and disconnected and reconnected the battery and it won't attempt to turn over at all. Swapped back in what I thought was the bad rcm and still nothing. I read at some point you could manually close the relays on the board to test if they were bad. Would that be an option?
I will have to defer to the RCM experts on that question, but I believe I am correct in saying that when you turn the key to the on run position the contacts in the relays should close.
