Speedy4x4
The m112 has alot of potential, but the $$$$$$$ needed far it is greater than the rewards.
If it wasn't for the coding, soooo much would have been accomplished.
Why it took so long for a main company to to get coding and make ecu's and harnesses to swap a hemi into other vechicles. TY mb.
When chrysler finally split from mb then they let holley in so they could don't here thing.
I'm interested in what you mean here....
Given there are aftermarket ECU's that can easily handle V6's (Emerald K6 comes to mind); if this is a limitation I would like to investigate if those limitations can be resolved using a aftermarket ECU.
I'll keepa searching in the forum!
