Thomas Lewellyn
My Crossfire is stuck in the garage. 2006 Roadster - 41,000 miles, pampered.
Fully charged battery, everything seems to be working electrically. Turn key to engage the starter and nothing happens. Happened last week, and after trying a few times it started. Drove around town without problem. Tried to start yesterday and again nothing. Disconnected the battery and charged battery just to check charge level. Also, stuck in park. Sometimes I can get it out of park, but not consistently. I'm afraid this may be above my skill set. Thanks in advance.
Check your ground cables make sure there is no corrosion at the battery where the cable goes into the battery post fitting and where the ground cable attaches to the fender well, unbolt the ground cable from the fender well clean it with a wire brush and then reinstall it and see if that helps, oh and one more thing you are definitely not driving that car enough you need to drive it more it helps keep everything in better working order, keep us up-to-date and we will try and help you as much as possible. Next time you get stuck in park read your owner's manual and it will explain how to overcome that it's not difficult all you need is a unsharpened number 2 pencil or a small screwdriver doesn't matter if it's a Philips or a straight blade you're just going to stick it through a small hole that has a flap next to the shifter and push down that will unlock the shifter and allow you to put it in neutral.
