Old Apr 21, 2016 | 08:46 AM
  #196 (permalink)
sirharper's Avatar
sirharper
Default Re: A potential nightmare averted… thank you Crossfire Forum! Crankshaft Position Sen
Originally Posted by BenzFire
If it's the CPS it will 9 times out of 10 trigger the Check Engine light after trying to crank it
about 5-10 unsuccessful attempts in other words the engine will turn over but the car will not start!
now on the other hand if you turn the key and nothing happens, no engine turning over
or anything other than the lights coming on, on the dash... then it's not your CPS
but your RMC the problem. Cheers!
What's happening is it runs fine then without warning just stalls. So far once on the Interstate (rush hour, middle lane, scary) and once at a red light. Both times I put it in park reinserted the key and it started right back up first try. Never any issues with starting it. I think I'll still try the CPS first but keep a close eye on the RMC also. I don't think fuel pump, I had a fuel pump problem on my Hemi and when it stalled it won't restart for hours.
