ala_xfire
1. new air filters
2. clean the MAF/IAT sensor
3. change the oil, Mobil1 0w40 and Mann fleece filter
4. change out the brake fluid and install SS brake lines ( RedLine Blue and lines from Rob at NeedsWings )
5. change the differential oil
6. change the power steering fluid - Pentosin CHF 11s
7. replace the fuel filter
8. flush the cooling system - Zerex G05 / distilled water 50/50
9. new plugs and Magnecor wires ( from Rob at NeedsWings )
I did all the above on my 2005 Roadster at about 55,000 miles
I also changed out the top hydraulic fluid, not sure this was necessary ( also Pentosin CHF 11s ).
Probably should look into getting the transmission fluid changed too .......
Yep. This is a good list for any vehicle.
And it sounds eerily familiar...
