Old Apr 22, 2016 | 05:54 PM
ZERACER
Default Re: cost for replacement of Left side value cover and gasket
It is most likely your breather cover just above the valve cover. This is a common problem from time to time. Do a search on the Forum and do it yourself, if you can. No gasket, just clean it up and reseal with silicone seal. Total cost, a tube of silicone you can use again.
