Old Apr 22, 2016 | 11:16 PM
GraphiteGhost
Default Re: Weak air flow from heater vents
Hello! Have you ever taken the AC/Heat control head out for any reason? There is a couple (if I remember correctly) of 'keyed' shafts that MUST be correctly inserted to properly 'direct' the airflow. The shaft(s) control the manual damper positions inside the system plenum chambers. Just a thought, if not correctly attached, you'll never get proper airflow control.
