Old Apr 29, 2016 | 04:36 PM
onehundred80
Default Re: Weak air flow from heater vents
Originally Posted by Oconnom
By fan controller , I mean the electronic component that fits to the fan housing, not the actual rotary **** on the dash. Fan operates normally and speeds up as **** turned up
OK, but is this a new problem that occured after fitting the controller?
Is the controller new, used?
You did put everything back as it should be?
