Old Apr 29, 2016 | 04:40 PM
Oconnom's Avatar
Oconnom
Default Re: Weak air flow from heater vents
OK, but is this a new problem that occured after fitting the controller?
Is the controller new, used?
You did put everything back as it should be?
It was a brand new controller unit. To be honest, I don't know whether it was working OK before I changed it. The best of controller failed in the 'always on mode'.
I suppose the new controller may not be giving full voltage at max speed, I'll check
