Old Apr 30, 2016 | 04:25 PM
ala_xfire
Default Re: After weeks in the shop, the car won't start
3 times and then nothing is SKREEM module issue.
You can disconnect the negative battery terminal ( which resets the electronics ), and it will then try 3 more times.
The is the security module that reads the chip in the key fob and signals the PTCM that you are the owner and not a car thief. Unfortunately, a LOT of SKREEM modules have been failing lately, beginning to suspect that 10 years is about the life expectancy.
( it is located inside the dash up behind the instrument cluster, it is not plug and play, it must be coded to your key )
Some have been lucky and found that the lead from the SKREEM to the key ring antenna was the problem.
