Re: Rear wing, malfunctioning.
Pizzaguy,
Unless I misunderstand your post? The top stop working about 2 weeks ago, checked cylinders, found 2 leaking. Have been able to raise and lower the top, manually, ever since then. It just wouldn't work because fluid was low. Was unable to lock tonneau then, with no tool to latch the cover. Switch wasn't blinking then, and spoiler was working. Removed cylinders, with electric sensors attached to driver's side cylinder. After removal of both, light was blinking and rear spoiler would not go up using manual switch. Still worked at going up once I reached 60mph. My 2 questions(maybe not explained clearly) were as the tonneau cover not being latched causing the blinking or because the disconnect of the two electrically connections causing the problem? Blinking light and spoiler not working manually. Clean as mud now???? LOL.
Dennis
