BibaResto
Oil filter: It leaks. I've not searched the ends of the earth, but can't find a filter 'wrench' for it. Pep Boys have a 74mm 15 groove filter which won't work since it is supposed to be 14. Also, after I find one is the arrow on top of the filter indicating loosen or tighten? I have a bad feeling that after I've changed with the correct oil, installed a new filter (the good kind), it will still leak. Too bad Mercedes hadn't heard about metal canister type oil filters back in '03. Essentially it is the same set-up on the '58 & '62 Alfa Spiders in my shop.
