Thread: Check engine
Old May 4, 2016 | 09:55 AM
kingdavid54's Avatar
kingdavid54
Default Re: Check engine
[QUOTE=rodrofilo;865583]
Originally Posted by amx1397
Maybe the pump wasn't bad,, but the filter/regulator (is clogged or not regulating the filter and regulator are in one,, in other words you have two items in line from the tank to the engine one is the fuel pump the other is the fuelfilterregulator jim[/QUOTE
I changed the filter with a new one and the problem is still there, a problem that the car didnt have until they changed the fuel pump
Just a thought, could it be that whoever changed the fuel pump did not hook the fuel lines up correctly? Is that possible? I know the fuel filter has four lines.
