Old May 5, 2016 | 10:54 AM
onehundred80
Default Re: stalling at lights
Originally Posted by nonamejane
Hey guys, My 2005 Roadster is stalling at lights. It seems that it occurs more often when I am caught by a light and come to a abrupt stop.. when i try to go again the car hesitates and I have to give it extra gas to go. No engine lights come on the dash when it is doing this. There was one point that I thought the car was going to shut off because it was puttering so I put it in neutral which seemed to bring the rpms back up and then put it back into drive and it ran like normal. I am thinking that I need to replace the fuel filter (as far as I know this hasn't been done and the car has 93,000 miles)
I just wanted to check in with all of you to see if anyone has any other suggestions.
Just a little more info:
    I recently changed out all ignition cables (due to me breaking one while replacing the sealent on the engine oil breather)
      Thanks for any of your thoughts!
      My guess is that a cable is not firmly attached to a plug or two, three?
      I always question why people change the CPS it does not wear as there are no moving parts, I think bad connections are the main culprit for problems.
      The transmission cap is just missing the lock on it, otherwise it functions the same.
