Re: Baseline Dyno Run Results
All I'm saying is the car will not run over 5,000 rpm on a dyno and nobody I have spoken with (professionals) knows how to make it do so. So, you be the judge on his dyno that shows 6,200 rpm !!!
Now let's drop the subject. If you want to see a real "stock" baseline dyno take a look at Woody's. Then you can compare mine, which is from my slightly modified car.
