Thread: SRT6 Fan Woes
Old May 7, 2016 | 01:31 PM
onehundred80
Default Re: SRT6 Fan Woes
Originally Posted by Cal_Cobra
............... Not only that, but it had gotten so hot, that it melted the front radiator grille, it melted it outwards. I was thinking that perhaps the fan was connected backwards, and instead of sucking cool air from outside to the inside to cool the engine down, that it was actually blowing outward, not cooling the engine and acting as a heat gun on the radiator grille and melting it.
Any thoughts on what's going on? At least I know my fan is running, but clearly it's the engine is getting very hot. Is it possible the fan is backwards?
Thanks!
Brian
These grilles are made from ASA (Acrylonitrile Styrene Acrylate) and the temperature of a hot radiator is enough to cause the part to distort. Heat distortion temperature is what they call it. For this material it ranges from 180 to 220 degrees F.
That is one mess you have there, if the distortion was only on one side it would look like an Elvis Presley sneer.
