I have spent the last few evenings building up the ECU kit for my multi port throttle body project, and thought you might like to see some pics before I do the full write up on my site.
So far I have uploaded some code to it and had it running on the bench with a simulator board that replicates all the normal sensor inputs like MAP, throttle position, RPM, IAT etc. (first time my desk has done 15,000 RPM!) Then I spent this evening fabing up the mounting bracketry and starting the wiring looms. Surprisingly its all going according to plan ...so far. Still LOADS more to do though. Here's the pics:
The kit:
Relay board mounted. This connects to all the sensors and injectors and provides power to the various sub-circuits.
ECU mounted. That loom was a real pain to make up!
PC port and status lamps.
