Re: 2004 crossfire ticking noise
Automatic or manual. If it's manual, check the belt tensioner Damper. It could be the bushing on the damper are worn off and the damper is rattling. You should not have an oil light on unless you do not have the proper amount of oil. Maybe a sensor or over filled. To much is just like not enough.
